Re: Re: Bad O-rings. Should I overbore and High co
Posted by Jonathan Mirgon on April 11, 2004 at 17:19:17 from (205.208.129.15):
In Reply to: Re: Bad O-rings. Should I overbore and High compre posted by justin on April 11, 2004 at 15:49:46:
The c-152 does not have o-rings on the sleeves, If you are getting water in the oil you probably have a cracked head or a leaking headgasket. If the tractor runs good and does not smoke I would just pull the head, have it checked for cracks and then replace the head gasket.
Post a Followup
: Re: Re: Re: Bad O-rings. Should I overbore and High co
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
