Farmall Tractors Discussion Board
Pto Hydraulics on 1944 Farmall M leaking.
Posted by Rod Hergott on October 23, 1999 at 20:09:44 from (209.115.205.237):
The hydraulic system on the pto looks like a Char lynn but I couldn't find any identifying labels. The unit is sealed with only one seal on the front where a shaft comes out with a sprocket on it which is hooked up to the pto via a chain drive. This seal is leaking badly and I'm not in the mood to replace it before spring. What will happen if I leave the oil level below the level of the seal? How full am I supposed to fill the pump anyway? If I need a new seal can you tell me what size etc.? Help.
Thanks, Rod.
Post a Followup
: Re: Pto Hydraulics on 1944 Farmall M leaking.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
