H carb and clutch
Posted by Doug on April 15, 2004 at 12:52:30 from (65.176.81.232):
Have a new motor in a 1948 H. Been trying to dial in the carb I rebuilt with little luck. Can only get it to run with the choke closed. Tried to turn in the idle screw to give it less air as I open the choke but still getting too much. Was wondering if the mainjet could be sucking air too. Have a new mainjet that came with a piece of packing. Where does the packing go? Tried to adjust by the sequence they give in the manual but didn't work either. Starting with the mainjet 3 turns out and the idle screw 1 turn out. Turned the govenor control screw to open the butterfly slightly until the rpm picked up a bit, but still can't get it dialed in. Valves are OK at 0.017. Also, can you replace the clutch shaft seal without splitting the tractor. Looks like you may be able to remove the u-joint type knuckle from the under side to get at it. Leaking gear oil bad from the differential around the clutch shaft. Mostly only when in reverse. Probably another original leather seal. Thanks for the help.
Home
| Forums
Today's Featured Article -
Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
