Re: Converting to 12 Volts
Posted by Bob on April 15, 2004 at 18:30:22 from (66.163.134.177):
In Reply to: Converting to 12 Volts posted by Scotty on April 15, 2004 at 17:55:42:
Get a generic 12 Volt coil that states "no external reistor required, for about $5.00 to $10.00 more than a resistor will cost you, and save yourself a lot of agravation!
The problem with using a resistor is that not all coils draw the same current, so a certain value converting resistor that works well on on type of coil may be too low in value for use with another coil, causing rapid point wear, and an overheated coil, or with another coil the value may be too high, causing weak spark.
If you insist on a converting resistor, a "real" auto parts store should be able to come up with one to try. When you get it running, check for 5 to 7 Volts on the resistor (switch) side of the coil.
Post a Followup
: Re: Re: Converting to 12 Volts
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
