Re: Want to crank Super H
Posted by Bob M on April 19, 2004 at 07:37:23 from (165.170.128.66):
In Reply to: Want to crank Super H posted by Neal in Alabama on April 18, 2004 at 20:03:16:
Neal - You can crank the engine simply by connecting your negative jumper cable to the starter switch terminal (the heavy switch mounted on top of the starter), and positive jumper to the tractor frame. Then crank the motor by working the starter switch rod. Just make sure the ungrounded battery cable terminal is protected from contacting grounded metal in the battery box (wrap it with tape, etc) before making the jumper connections. If your ignition wiring is intact you can run the tractor jumpered up the same way. But in order to not cause any damage, first remove the wire from the BAT terminal on the regulator. Also limit run time to only a few minutes. Otherwise feeding the coil 12 volts without a series resistor can cause it to overheat and may also burn out the points.
Home
| Forums
Today's Featured Article -
Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
