Re: Re: Re: Re: Re: Re: Re: Re: Re: International
Posted by riverbend on April 28, 2004 at 18:26:22 from (208.160.33.119):
In Reply to: Re: Re: Re: Re: Re: Re: Re: Re: International A No posted by Larry Hardesty on April 28, 2004 at 15:18:00:
As long as you get a steady stream that continues for a few minutes, that means that you are getting gas to the carb. It might take a while for whatever that could be blocking up the fuel line to drift back into place. You might want to catch the gas in a can. No sense burning down the shed. If you have got fuel and the carb is good enough to start it, it will run. Warming these simple carbs up does not affect them too much. Do you have another condensor laying around that you could try ? Usually it is the electrical stuff that is affected by heat. And it is usually the coil that craps out. You can check the coil with an ohm meter. Try measuring the resistance between the two small terminals, between each terminal and the HT output, and all three and the case when the coil is cold. There should be a couple of ohms, not zero and not infinite. If it is hard to get a steady reading, try disconnecting it or an analog meter. Check it again when it stops running. See if the readings are the same. Be sure that the ignition is off, if there is any voltage involved, you could burn up your meter. Same with the condensor, but they are made to store voltage, so be sure to short the lead to the case before you check it. The condensor should measure infinite or open if it is good. Greg
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
