Re: IH 240-U Carb Problems
Posted by rebuilder on May 01, 2004 at 18:14:36 from (216.241.134.128):
In Reply to: IH 240-U Carb Problems posted by Jerry on May 01, 2004 at 14:23:57:
Jerry;
I am assuming you have an aluminum carb as the older Zenith's were cast iron(which I generally prefer as they held up better) With the aluminum carbs I usually find corrosion(a white powder from oxidation) inside and in the jet passage ways. Mostly found on carbs which have set in barns for too many years without being run. I have found the easiest way to clean away the corrosion is to remove all jets and bead-blast. Carb cleaner will not remove the corrosion. Just make sure the passageways are cleaned of the blasting residue with mulitple rinses( I find paint thinner works well and will help remove any oily residue and varnish along with blasting dust. If after you have cleaned the carb and you still do not get gas to your plugs there are several possible problems with either the fuel supply end or on the dispersal end I.E. out of tune intake valves(will not suck gas/fuel mix into the chamber.
Post a Followup
: Re: Re: IH 240-U Carb Problems
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
