Re: 504 Generator Troubles
Posted by Bob M on May 08, 2004 at 16:33:25 from (66.67.11.95):
In Reply to: 504 Generator Troubles posted by Kirk Grau on May 08, 2004 at 15:54:11:
Kirk - Definitely sounds like a low battery problem and would account for the gradual loss of power under load. Reason: As battery voltage drops so does the spark voltage. And the higher the load, the more spark voltage is required to fire the engine.
How to fix? If your 504 has an ammeter, punch below for a trouble shooting chart. If it just has an idiot light, you'll need a DC voltmeter place across the battery to help sort it out. Then substitute "voltmeter reads 13.5 volts or higher?" for "does the ammeter indicate charge?" in the trouble shooting chart.
Recommend however you give the battery an overnight charge before you begin. Good luck!
Post a Followup
: Re: Re: 504 Generator Troubles
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
