Farmall Tractors Discussion Board
Re: Charlynn pump on pto has leaking seal.
Posted by GeezerMn on October 27, 1999 at 09:39:22 from (216.161.105.79):
In Reply to: Charlynn pump on pto has leaking seal. posted by Rod Hergott on October 25, 1999 at 19:19:09:
After-thoughts----- The info I gave on a previous post applys to a pump with diecast alum.
front housing.If you have a pressed steel housing
there are gaskets at hose connect blocks that hold
hyd.pressure.They may leak.Also seal info.may not apply.To slide seal over keyway & snap ring groove wrap a layer of electrical tape from
bottom to top of shaft & lube.
Post a Followup
: Re: Re: Charlynn pump on pto has leaking seal.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
