Re: Belt Pulley Oil Leak
Posted by Haas on May 19, 2004 at 18:32:19 from (12.65.6.88):
In Reply to: Belt Pulley Oil Leak posted by MIKE on May 19, 2004 at 17:40:45:
I posted an answer on this a few days ago. Here we go again. I think the pulley flange has three bolts, not four, but I could be wrong. Anyway, take the bolts out of the flange. It may take a little perswasion with a pry bar, but after the bolts are out, the flange and the shaft with two bearings and a gear on the end will slide out. Be prepared to catch the oil that will come out too, as there is no drain. The small sump of the pulley is fed from the transmission and overflows back to the transmission. Since it is an overflow system, and this is the high point of the transmission sump, any water tends to accumulate there, so you may get some water out too. Running the pulley occasionally will help keep the water out and if the tractor ever works and gets hot, the water will evaporate. If it is allowed to accumulate in the pulley housing, the bearings will eventually go bad. There is no gasket under the retainer flange, only shims to adjust the gear lash. So to avoid leaks, the shims and surfaces must be completely clean at reassembly. The shims should be put back like you found them unless you want to go through the process of readjusting the gear lash. To replace the seal, you really need a bearing press. The gear, and both bearings must be removed to replace the seal. Seems I recall there is a spacer on the shaft as well. It's not really a bad job. I took mine to a shop that had a press to remove and reinstall the bearings and gear. I do believe, though that if you have some experience in such things, you could do it with a puller without a press. When you have it reassembled, put a quart of gear oil in through the fill port on the pulley housing to supply initial lubrication when you restart. Any excess oil put in will just go into the transmission.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
