Re: Found a 300U problem, big to me
Posted by Ken in Iowa on May 19, 2004 at 19:47:30 from (12.64.146.117):
In Reply to: Found a 300U problem, big to me posted by Loren on May 19, 2004 at 19:28:22:
Loren: The hydraulic pump is on the right side of the engine and is connected with 2 pipe type oil lines to the reservoir under the seat. The lines are sealed with O'rings as well as the control valve assembles on the right side of the reservoir. A gasket seals the reservoir to the top of the housing. The dipstick is under the seat. If you remove the res. besure to inspect and clean the hyd. screen. Before you split it get a book or some advice from a tech. in your area.Good Luck, Ken
Post a Followup
: Re: Re: Found a 300U problem, big to me
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
