Re: Leak at axle on H
Posted by Bob in SE Nebraska on May 28, 2004 at 19:33:48 from (162.40.71.48):
In Reply to: Leak at axle on H posted by Dave in CT on May 28, 2004 at 17:57:51:
Not sure where you mean the leak is. It sounds like the leak is where the axel comes out of the axel housing near the wheel itself. If this is the case it isn't a bad job at all. Raise the tractor, remove the wheel and pull that cap off of the outer end of the axel housing. The seal is right there and a new one from Case / IH isn't very expensive and I would also replace the felt piece that is located with the seal. The biggest challenge with doing that is the handling of the tire and hub. It is heavy and kind of hard to deal with. I use a shop crane and it works pretty easy with the crane. Hope this helps.
Bob
Post a Followup
: Re: Re: Leak at axle on H
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
