Re: Re: Re: farmall m firing order
Posted by TomH on May 29, 2004 at 17:26:06 from (206.101.85.87):
In Reply to: Re: Re: farmall m firing order posted by Jamie Stratton on May 29, 2004 at 14:09:03:
Here's another try. Pull the spark plugs from the cylinders and put your thumb over the #1 hole (closest to the front). Get someone to crank the starter or turn the engine by hand until you feel air pushing your thumb off the hole; that's when the piston is on the compression stroke. Now look at the big pulley at the front of the engine, right below the govenor you should be able to find the timing mark close to the pointer, move the pulley until the mark lines up with the pointer (if all of the spark plugs are out you can crank the engine by turning the fan by hand). While you're turning the engine take a look at the distributor and watch which way the rotor turns. The engine is now where the spark should fire #1. Loosen the distributor and turn it until the points just open as it climbs up the cam (remember which way the rotor will turn), that's when it will fire. Now put the rotor on the distributor and see where it's pointing, the connector on the distributor cap where the rotor is pointing is the one you want to connect to #1 spark plug, then connect the other plug wires in the firing order.
Home
| Forums
Today's Featured Article -
Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
