Re: Farmall M Distributor timing.....it wont start
Posted by rustyfarmall on May 30, 2004 at 12:44:48 from (199.120.81.217):
In Reply to: Farmall M Distributor timing.....it wont start.... posted by Jamie Stratton on May 30, 2004 at 12:01:06:
I assume you have already checked and ruled out everything else? Do you have spark? Is it getting gas? Are the valves operating correctly?
Pull a spark plug wire off of the plug, crank the engine and see if you have spark. If you do have spark, and everything else checks out OK, then you may need to advance the timing by rotating the distributor, if the timing is too slow, the engine will not start.
Also, if there is no spark, check for grounded connections inside the distributor. I know what you are going through, I have been there, and it can be very frustrating. Just remember the old rule, if you have fuel, and you have spark, that engine has to run. It's just a matter of getting it all to happen at the right time. Hang in there.
Post a Followup
: Re: Re: Farmall M Distributor timing.....it wont start
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
