Re: Carburetor float help!!
Posted by Bob M on June 11, 2004 at 07:50:48 from (165.170.128.65):
In Reply to: Carburetor float help!! posted by Andrew Kopel on June 11, 2004 at 06:14:18:
Andrew - Suggestions for a few things to try: 1 – With the carb still on the tractor remove the float bowl. Lightly lift the float with one finger (to close the needle valve) then open the fuel shutoff at the sediment bulb. If any gas appears the problem’s somewhere around the needle valve. Look for a defective needle or seat, junk caught in the needle valve, bad or missing gasket ring under the valve seat fitting, or possibly a crack in the casting where the seat screws in. 2 – Now let the float drop with the shutoff valve still open. Gas should run freely from the float needle valve. Lifting the float again should immediately stop the flow. 3 - If the above checks out, reassemble the carburetor then remove it from the tractor. Invert the carb and shake it up and down. You should hear a distinct rattling as the float moves inside. If you hear nothing the float’s binding somewhere – you’ll need to remove the bowl find it. Or with the carb inverted, apply light and gradually increasing air pressure at the fuel inlet. At low air pressure (5 psi or less) you should hear nothing. However as pressure increases at some point you should hear a hissing or farting sound from within the carb as as air pressure lifts the needle & float. (I applaud your commitment to your new daughter for your use of “G” rated language, but I cannot think of a G-rated term which more accurately describes the sound!). Anyway if you hear air escaping even at low pressure, it again indicates a float bind. Look for a bent or distorted float hinge, bent float arm, etc. Good luck and post back what you find!
Home
| Forums
Today's Featured Article -
A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
