Re: removing stuck pistons?
Posted by Kevin (FL) on June 18, 2004 at 20:57:45 from (12.77.202.119):
In Reply to: removing stuck pistons? posted by curtis on June 18, 2004 at 20:13:54:
Curtis, If you don't have a floor press, you can reinforce a piece of 6" channel iron the length of the deck and drill some holes that align with the head bolts or studs. Use a bottle jack that will fit inside the sleeve, shim up as needed and press the jack against the piston and the underside of the channel iron (after securing the channel). Stretch out some old inner tube around the jack's base so you don't score the sleeves--assuming they may still be usable.....Also, you can boil some water and fill up the water jacket right before you push on the pistons. That will expand the sleeves a little, especially if they're wet type sleeves. Have you removed the conn rod nuts so you're not trying to push more than one at the same time? Once you get one heading down a little you should be able to remove the jack and tap the piston from below. Don't forget to slip a piece of fuel hose over the conn rod studs. If you have a ridge, it'll need to be cut too. Be careful you don't damage the crank journals with all this beating and banging going on. Hope it works out. You could also say a prayer too.
Home
| Forums
Today's Featured Article -
Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
