Re: removing stuck pistons?
Posted by El Toro on June 19, 2004 at 04:47:48 from (205.188.117.22):
In Reply to: removing stuck pistons? posted by curtis on June 18, 2004 at 20:13:54:
Hi Curtis, I had the same problem on a Farmall A that was seized. I used automatic transmission fluid. They were still hard to remove. I used a 2X2 oak to drive them out. Several pistons can out with the sleeves. To get out the remaining sleeves I had apiece of alumium round stock under cut on a lathe to fit the sleeve. I then use the 2X2 to drive out the sleeve. I pulled the engine off the tractor so I would be able to steam clean the block. Use can use tygon tubing over the rod bolts so you don't damage the crankshaft. Some of the people that write in on here have used coke and brake fluid. Take your time and try all of these. I used a torch to heat the sleeves on the pistons that came out together. I only needed the connecting rods since I was installing a new sleeve kit. If the sleeves move a little with the pistons, keep squirting any of those items over the edges of the sleeve. We had a saying when using that torch "come or bleed". I had to pull the crankshaft too, since it had to be machined. I got away with just having it polished and using .002" under size bearings on the mains and rods. If the rod bolts are removable I'd remove them. What tractor is this? Good Luck, Hal
Home
| Forums
Today's Featured Article -
Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
