Re: Checking a generator
Posted by Bob on June 19, 2004 at 19:22:15 from (66.163.134.177):
In Reply to: Checking a generator posted by Joe on June 19, 2004 at 17:50:41:
A 12 volt battery, after sitting a few hours, will show about 12.5 volts. To charge the battery, the generator output needs to be in the 13.5 volt to 14.5 volt range, as controlled by the voltage regulator. Although some will argue with this advice, it is best NOT to be pulling the battery cable off with the tractor running. Check the battery voltage with the tractor revved up to 3/4 speed or so. If the battery voltage is below the range I've listed, check right at the generator "A" terminal. If the voltage is still low there, TEMPORARILY "full field" the generator by jumpering the "F" terminal on the generator to ground. If this brings the voltage up, suspect the regulator, and check the wiring between the generator and regulator. If "full fielding" the generator does not make it charge above 13.5 volts, you have generator problems. Engine electrical and ignition systems make a lot of electrical noise, which can screw up cheap digital meters, and cause inaccurate readings. I usually use an analog meter around this equipment, or a quality digital meter.
Home
| Forums
Today's Featured Article -
A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
