Farmall Tractors Discussion Board
Re: Restoring an H vs M
Posted by Bob M on October 30, 1999 at 18:15:44 from (171.218.205.222):
In Reply to: Restoring an H vs M posted by Brian on October 30, 1999 at 17:55:31:
Brian -
I restored a Super M a couple years ago, and finished a Super H this summer. Though they look identical, the H and the M share only about a half dozen parts: the steering wheel, seat, generator, voltage regulator, the electric box and the lights. Virtually EVERYTHING else is unique to the individual models. The tractors however are put together exactly alike - just the M parts are always bigger.
The drivetrain on an M is no less durable than on an H - it's been sized to accomodate the higher horsepower is gotta handle. The statement that an M is more likely to be worked hard and worn out is not necessarily true - some of the most worn-out tractors I looked at before I got mine were H's
For a restorer, each tractor has it's advantages: Everything on an H can be reached from floor level (you sometimes need a stool or stepladder to work on the top of an M) An H with the wheels set in takes up less space in the shop or garage. The H weighs about a ton less than an M - can be pulled on a trailer by most any size pickup.
On the other hand, if you're gonna use it to do real drawbar work, the M has half again the usable power of an H. The M has a delightfully booming exhaust note, and when parked in the middle of a row of H's at a tractor show, M's often elicit comments like: "Geez that's BIG..."
So the choice is yours - but either way you won't go wrong... Good luck!
Post a Followup
: Re: Re: Restoring an H vs M
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
