49' M fuel/timing question
Posted by jamie on June 23, 2004 at 19:45:19 from (24.178.79.172):
Just fixed a problem I've been having with the intake on the sediment bowl getting blocked by replacing the fuel bowl and line with an inline filter. No more problems maintaining good gas flow to the carb but even so, it tried to die on me coming back to the barn after running it for quite a while with no problems. I had pulled back on the throttle and the engine hesitated and tried to die. Normally, it has good throttle response. I set it back to idle and it kept running (got used to that with the fuel blockage before). I verified that there was plenty of fuel and flow to the carb by draining gas out of the carb. I thought it might have been running a little rich so I turned the main adj screw in about a turn. It cranked right up and ran fine to the barn. Since I haven't had time to build a tall enough shed for the tractor, I have to take off the muffler each time I put it in the barn. When I did, I pulled back on the throttle lever again to see how it would react then and I got a little fire out of the manifold initially. Is this because I now have it too lean or is the timing a little late? I didn't notice that before I changed the main setting on the carb. The timing has been set and the coil,spark plugs, wires, points, cap,rotor were all replaced prior to the problem. I know I need to check the valve clearance. Could that be the problem? This may be normal, but one other thing I notice is that when I crank it up I always get a puff of smoke which I assumed was some oil leaking past the rings burning off. Other than that, it runs strong and sounds great. I'm using 10w-40 Delo in it I believe instead of straight 30w. Before I changed the oil, I don't think it smoked at start-up like that. Should I go back with straight 30w? It doesn't burn much oil at all, just a little puff here and there. I haven't checked the compression (low compression gas/dist engine) yet, but I believe its good. The tractor has a rebuilt carb (float needs to be adjusted - noticed a little gas dripping out the carb), a new manifold, and is a 12volt system.
Home
| Forums
Today's Featured Article -
Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
