M, MTA carb
Posted by Hayfarmer on June 27, 2004 at 09:08:18 from (12.160.171.192):
On my SMTA I have trouble getting throttle response at all positions. Sometimes it works fine through the whole range, other times it stays at mid range and jumps to full throttle when I move the handle but it does not progress smoothly through the range. Throttle linkage seems to be loose enough and governor seems ok. I am thinking it may be the tube and rod between governor and carb. I can losten the bolts and wiggle it around and it works ok, but then I have problems again later. Can a person put a busing in the tube or is it better to just get a new one from IH or is it availale?
Post a Followup
: Re: M, MTA carb
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
