Re: H Starter Question
Posted by Bob M on June 28, 2004 at 14:17:10 from (165.170.128.66):
In Reply to: H Starter Question posted by Leon on June 28, 2004 at 13:31:11:
A couple thoughts: 1 – Is the ignition timing set to spec? If timing is early (BTDC) it can a create a lot more work for the starter as it must crank against firing pressure near the top of each piston stroke. Can easily be tested by cranking with the ignition switch off. If the engine cranks faster with the ignition off, retard the timing. 2 – The starter may have become heat sensitive. This seems unlikely however as the starter lives out in the relatively cool space behind the engine. (This was more of a problem on some 8 cylinder engines where the starter is tucked between the engine block and the hot exhaust manifold...) Test by taking battery voltage readings when cranking both cold and hot. If it’s a temperature-related starter resistance problem, battery voltage will be HIGHER (starter draws less current) when the starter is hot. If you find that’s the problem best take the starter to a starter shop for a going over. I don’t know offhand what the current draw is for a 6 volt starter on an H – I’d guess 300 amps or so. Battery voltage however should not drop below about 4 volts when cranking.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
