Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re
Posted by Hugh MacKay on June 29, 2004 at 04:09:15 from (209.226.247.17):
In Reply to: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re posted by Stan(VA). on June 28, 2004 at 12:29:57:
Stan: I should clarify one item. The IT manual I have covering the C-135 engine is as it applied to the 404 and 2404 tractors.
This 140 I have was not run in 10 years, just sat in a heated warehouse. They never could get it going, since they had bought this farm and turned it into a wholesale tropical plant greenhouse operation. They had the wiring all messed up, still 6 volt generator and trying to use neg ground. I doubt it the tractor has more than 500 hours on it since new. It drives like 130 did in 1958. They had also left it half full of coolant.
After completely rewiring, alternator, amp gauge, battery, even light fuse and switches. Water pump and top half of rad were mass of rust. Rebuilt pump and recored rad. After all this I couldn't gey it to run smooth, so decided to adjust valves as it needed a new valve cover gasket anyhow. Went by book and used 0.014 for both intake and exhaust. It had been way off. This setting improved it, but I was not satisfied. I noticed the exhaust valve setting for C-135 in 404 is 0.020. I gradually increased my exhaust valve settings and at 0.018 the 140 works perfect.
Post a Followup
: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
