Re: International 584 with front loader
Posted by JB on July 07, 2004 at 18:58:45 from (24.157.143.220):
In Reply to: International 584 with front loader posted by ben UK on July 07, 2004 at 10:51:50:
Hi, in Canada a 584 with cab & 2250 loader would be about $17,000 CDN. see URL.
My brother has 495 (one size smaller than 584) with 2250 Quick Attach loader on it. The 2250 is a great loader but it is to heavy for front end on 495. I wanted him to put the loader on his 684 but he insisted on the 495 and has sheared off hub bolts, split the channel iron on the front axle etc.
But I believe the 584 has the same front axle as 684 which is much heavier. So you should be good.
These are great tractor except for the parking brake problems. Always be sure to use only IH Hytran fluid in hydraulics/transmission.
If it has a T/A when the T/A is in High position this is direct drive and LO position is in T/A drive.
A quick check of T/A is to put tractor on a steep slope with front pointing down the slope.
With T/A in High position and gear shift in 4th High range, turn the engine off and engage the clutch and don't touch the brakes the tractor should not roll forward. If it does roll forward it should turn the engine over. Repeat again with T/A in LO position.
Good luck
JB
Post a Followup
: Re: Re: International 584 with front loader
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
