Farmall A Upkeep Revisited Still
Posted by Christopher S. Dunn on July 09, 2004 at 05:26:23 from (216.141.73.90):
Well, folks, I am back again for more sage words. I had the old girl running pretty well after the carburator and gas flow problems were solved and then, as the PTO shear pin issue was resolved I could run the tractor long enough for it to start stalling.
I read through a lot of posts and some of the archives (now that it's back up!) and figured it must be something with the magneto and/or the following ignition parts going to the plugs.
Over the last couple of days, I pulled the distributor cap, checked the plugs, replaced the plugs, adjusted the breaker points, then replaced the breaker points and set the gap on them. I also replaced the rotor.
The funny thing is this: once I opened her up and messed with the breaker points, I haven't been able to get her to run. I will say that getting the points set was a Bit&#! and I am not sure if the manual was serious about checking the timing mark on the flywheel and all that. I was pretty sure that was for setting the timing on the mag and I didn't think that was necessary for just setting the breaker point gap.
Was I wrong about that? What else can I do?
I know it was something I did, but exactly what it was I am uncertain. It was running (if only for 15-25 minutes at a shot) before I started and now it's not firing up.
I AM getting spark from the coil and all the way to the plug wire ends. I am getting fuel flow and I have a full tank. The battery is strong like bull. SO... the question I have is this: If I have to mess with the timing of the mag, did I already screw the pooch on it by getting in there in the first place? Will I have to remove the mag assembly from the tractor to properly align and time it if this is the case?
I await any sage and semi-sane responses.
Christopher
Post a Followup
: Re: Farmall A Upkeep Revisited Still
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
