Re: Farmall H timing/dist.
Posted by gene on July 15, 2004 at 22:50:30 from (208.144.172.164):
In Reply to: Farmall H timing/dist. posted by Farm w/Junk on July 15, 2004 at 20:51:49:
LOOK, YOU HAVE RECEIVED SOME VERY GOOD HINTS/TIPS IN PAST. YOU SEEM TO BE CENTERED ON THE CARBURATOR. I'D BET YOU SCREWED SOMETHING ELSE UP ON THE OVERHAUL. YOU PREVIOUSLY SAID SOMEONE ELSE REBUILT THE CARBURATOR - THEY PROBABLY KNEW WHAT THEY WERE DOING. SET THE IDLE SCREW AND MAIN (POWER) SCREW OUT ABOUT 2 1/4 TURNS. THEN KEEP YOU FINGERS OFF THE CARBURATOR. RUN A COMPRESSION CHECK. I'LL BET THOSE VALVES ARE NOT CLOSING PROPERLY. TAPPETS? GO BACK THROUGH SOME OF THE PREVIOUS ANSWERS, GET OUT THE SHOP MANUAL, AND DOUBLE CHECK EVERYTHING. AS MUCH AS YOU HAVE SCREWED WITH THE CARBURATOR IT'S PROBABLY NOT YOU PROBLEM. DISTRIBUTOR: THE ROTOR SHOULD MOVE, ONE WAY, AGAINST THE SPRING (ADVANCE), ABOUT 30 TO 36 DEGREES. THE ROTOR SHOULD NOT MOVE IN THE OPPOSITE DIRECTION. IF YOU WIGGLE THE ROTOR SIDE TO SIDE YOU MIGHT FIND A LITTLE MOVEMENT, WHICH AT THIS POINT I WOULD NOT GET TO EXCITED ABOUT.
Home
| Forums
Today's Featured Article -
Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
