Re: Farmall H presure plate question
Posted by Wayne Swenson on July 16, 2004 at 11:09:45 from (66.191.70.31):
In Reply to: Farmall H presure plate question posted by SCOTT IN MO on July 16, 2004 at 10:18:32:
Depends on your finances. As Allen in NE said, replacement is insurnace against future problems. I have done it both ways with success; if you know the clutch was working OK before, you could take a chance and just replace the friction disk. Clean off all oil & grease on the flywheel and pressure plate friction surfaces with a de-greasing spray and check the throwout bearing for roughness; be sure the grease zerk in the flywheel that lubes the bearing is functioning. (Align the single mark on the front pulley with the timing pointer; it lines up the zerk with the hole in the bottom of the clutch housing) Check the splines on the shaft and use a file to remove any sharpness. The disk must slide easily on the splines to be able to shift and not grind the gears to much. Use a non-greasy lube (WD-40, JB-80, graphite, etc.) and insert into the friction disk. Clean the friction disk with de-greaser also and install the parts withought putting your greasy fingers on the cleaned surfaces. Center the friction disk and tighten the cap screws carefully. I do not recall the torque value.
Home
| Forums
Today's Featured Article -
A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
