Re: Farmall H Belt pulley seal
Posted by Wayne Swenson on July 17, 2004 at 14:41:50 from (66.191.70.31):
In Reply to: Farmall H Belt pulley seal posted by Rock on July 17, 2004 at 08:42:00:
My 2 sons & I just re-did 2 gearcases for their belt pulleys on their "H"s". we had them on the bench but you can just remove the driven shaft on the tractor. Remove three capscrews under the pulley mounting flange and the shaft, spacers, & bevel gear will all slide out with a bit of assistance. Remove the cap screw on the end of the shaft and all the parts can be pulled off. I was able to obtain replacement bearings at no cost by going to an electric motor rebuilding shop. If my memory is corect you need a 6210 & 6208 bearing for the drive shaft. Remove any shields so the bearing will now lube itself from the transmission oil. Thoroughly clean all old grease residue before installing the used bearing. Factory bearings run $50 or so for the big one so it can be an expensive affair to replace them. NAPA wanted $45 for the 6210 size. I have a Case/IH dealer in town (Fergus Falls, MN) so otained the new seal, felt dust washer, and mounting gasket from them at a very reasonable cost. Carefully clean the metal spacers and put a VERY light coating of silicone on them just before assembly. Don't mix up the cap screws from the drive gear cover with the shaft cover; they are longer (don't ask how I found out) and will not compress the spacers under the pulley flange. mail me if you need more info.
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
