Re: power lift on farmall H
Posted by rustyfarmall on July 20, 2004 at 14:07:12 from (199.120.81.221):
In Reply to: power lift on farmall H posted by Hank on July 20, 2004 at 12:26:45:
The pump is an optional accessory, the tractor will run either with it, or without it. If you don't need it, drop it out, but get some help, it is very heavy. If you get under the tractor and look, you will see a cover plate behind the pump, should be 4 bolts holding it on. Remove the bolts, drop the plate, and then you can see what you need to do.
Post a Followup
: Re: Re: power lift on farmall H
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
