Farmall Tractors Discussion Board
Re: Fouled plugs on 560
Posted by Phil Auten on November 04, 1999 at 05:28:07 from (206.175.72.226):
In Reply to: Fouled plugs on 560 posted by Steve on November 03, 1999 at 21:12:07:
Steve,
72 PSI sounds quite low for a 560 gas. I believe you should be getting about 110 PSI for all cylinders, plus or minus 10%. I would check it again. Spin the engine over several times on each cylinder so you get an accurate reading. Then, squirt about two tablespoons of 30 wt. oil in the cylinder being checked and check it again. If the reading comes up significantly (more than a couple of PSI) the rings need replacing. If unchanged, check the valves for burning and proper sealing to the head. Good luck!
Phil
Post a Followup
: Re: Re: Fouled plugs on 560
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
