Re: 140 transmission leak
Posted by Haas on July 28, 2004 at 19:55:55 from (12.65.66.86):
In Reply to: 140 transmission leak posted by WalJohn on July 28, 2004 at 14:12:01:
Sounds like the seal at the front of the transmission is leaking. There is a shaft seal there, as well as a cap with a gasket over the end of the countershaft and bearing. Also, dowell pins. I had a leak like this on my C and one of the dowell pins was missing and the hole was all the way through into the transmission. Also, there was no gasket on the cover over the counershaft bearing. To repair this, you will have to split the tractor just in front of the transmission. This is not a real hard job, as when you get all the external things off, support the front and the back, and when you take out the 4 bolts there, the drive shaft will slide right out of the clutch. Replace the bolts with longer ones to make it easier to support, etc. You can roll the back part back on the rear wheels. Make sure the front is well blocked and use a shop crane or something similar on the back part. Make sure the clutch remains engaged while the driveshaft is out of it. If disengaged while the shaft is out, the plate will not be aligned anymore and you won't be able to get it back together.
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
