Re: No compression
Posted by Wayne Swenson on July 29, 2004 at 20:17:37 from (66.191.70.31):
In Reply to: No compression posted by Abe on July 29, 2004 at 09:38:51:
When you check compression, be sure that the throttle is wide open and the plugs are all removed. Tuck the coil to cap wire under a cap clamp and be sure the battery is fully charged. If someone has changed the Schrader valve core on the business end of the tester and put in a standard tire valve core, you will get very low readings. Get the correct (compression tester core) one from an auto supply store. Test all cylinders dry and then squirt 3-4 pumps of oil in each cylinder, spin the engine several times and retest again. If the pressure rises quite a bit in each cylinder, then you have a cause for ring replacement. Locate a good cylinder leak-down tester and use it to do a much better job of determining where your engine is loosing compression.
Home
| Forums
Today's Featured Article -
A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
