Re: Question for EL Toro (Hal).
Posted by El Toro on July 31, 2004 at 16:21:18 from (66.119.33.135):
In Reply to: Question for EL Toro (Hal). posted by Abe on July 31, 2004 at 06:04:07:
Hi Abe, Remove the valve cover and watch the rocker arms as the engine rotates, each valve should move freely. Rotate engine to No1 firing position with rotor at No1 plug wire, using a feeler gauge check valve clearances. They should have clearance of at least .017". This is the hot setting recommended by IH. You should have a clearance greater than this by several thousands on each valve. If No1 valves are ok, rotate the engine to No3, the rotor should be at No3, check valve clearances and adjust if necessary, then do No4 and then No2. Both valves are in the closed position and you should have clearances. Make sure you're on the compression stroke on No1 cylinder when starting this procedure. If the clearances are ok, you're probably looking at an engine rebuild. Hal
Home
| Forums
Today's Featured Article -
A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
