Farmall Tractors Discussion Board
Re: 12v Conversion Wiring help..!!
Posted by ltf in nc on November 06, 1999 at 16:43:43 from (206.228.213.61):
In Reply to: 12v Conversion Wiring help..!! posted by Gee on November 06, 1999 at 13:57:09:
To reduce the heat in the coil you still need a ballast resistor. Some new coils have one built in, others don't. From a discount auto supply get a ballast resistor that is 1.40 to 1.65 ohms and locate it according to the schematic you are using. Get yourself an isolation diode and replace the "idiot" lamp you are using. When you get the diode properly installed the engine will stop when you turn off the switch, if the engine stills keeps running reverse the diode as you have the polarity incorrect.
Post a Followup
: Re: Re: 12v Conversion Wiring help..!!
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
