Re: IH B-265 tractor - timing
Posted by UFO Man on August 08, 2004 at 18:26:47 from (66.243.138.57):
In Reply to: IH B-265 tractor - timing posted by Marie Art on August 07, 2004 at 16:50:22:
Marie, sorry it took me a while to find the service manual. First off, you have to remove the timing gear cover. I have done this on my B414 without taking off the radiator, belts and other stuff, so I think that it can be done without doing that on a B275. The gears that are under this plate have punch marks on them that line up with punch marks on the other gears. According to the illustration, the line ups are obvious. The engine on a B275 is timed at 20 degrees before top dead center, BTDC, which is indicated on the injector pump gear, if the illustration is accurate. If not: In the case of a pneumatic governor, and having the #1 cylinder at top dead center, TDC, measure from the marker in the cranshaft pulley to the timing marker. The distance should be 1 and 1/8 inches around the circumference, which is 20 degrees BTDC. In the case of a mechanical governor, with the flywheel TDC mark aligned with the scrib mark located on the left fornt flange of the clutch housing, you will have to remove the dust cover on the clutch housing to find this. Shut off the fuel and remove tht injection pump timing window. If the mark "E" os aligned with the scribed lines at the lower hole of the pump snap ring, that is 20 degrees BTDC. This can be adjusted by loosening the nuts on the pump mounting studs and moving the pump between the two marks on the engine front end plate and retightening the nuts. These scribe marks are a variation of about 3 degrees. The engine can be timed 22 to 16 degrees BTDC as it suits your needs. 16 is quieter but less powerful, 22 is full power but noisy and will reduce engine life. Hope this helps, let us know how it works out. UFO Man
Home
| Forums
Today's Featured Article -
Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
