Re: 460 Wont start Please help!!!!!!!!!!!!!!!!!!!!
Posted by captaink on August 11, 2004 at 13:28:00 from (66.115.212.249):
In Reply to: 460 Wont start Please help!!!!!!!!!!!!!!!!!!!!!!!! posted by Randy on August 11, 2004 at 13:01:45:
Things to check. Is there voltage to the coil? If not there is a break in wire from switch to coil. If there is, check for spark (spark = bright blue ½” spark) from the high tension coil wire to a ground when the engine is cranked? If not, check to see if the points are opening, then replace condenser, then replace coil. If there is spark, check to see if there is spark at the spark plugs. If so, check timing of distributor. Turn the engine until # 1 cylinder is Top dead Center on compression stroke (air escaping from spark plug hole.) When pointer on front crankshaft pulley is at TDC, make sure that the rotor is turned towards the terminal on the distributor cap that the #1 spark plug wire goes to. Then make sure the wires are in the firing order 1-5-3-6-2-4. This should prove out the ignition system. Good luck.
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
