Re: 650D/WD9/MD etc. injector pump Troubles...HELP
Posted by Ron in Nebr on August 23, 2004 at 20:52:00 from (65.172.143.27):
In Reply to: Re: 650D/WD9/MD etc. injector pump Troubles...HELP posted by Farmaller on August 23, 2004 at 14:09:27:
Thanks- I"ll check that out. I really don"t know if that"s the problem though, since I have had it running on deisel since I"ve bought it. Would a stuck rack keep the primary pump from pumping but still allow the tractor to run?
The reason I ask is because if I fill the secondary filter clear full of fuel through the bleed hole on top, then it gives a good spray of fuel when I bleed each injector and runs good for just a little while. Then it quits and it won"t bleed out the secondary filter. I took the output line off the primary pump and there"s just no fuel being pumped out, like I said in the first post, it just seems like the primary pump isn"t turning.
Post a Followup
Subject:
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
