Cub Steering - Can't Get It Back Together *?@$#
Posted by Paul_NJ on August 30, 2004 at 13:43:17 from (68.239.228.216):
I am stuck trying to put the steering back together on my 51 Cub. I can’t get the two (original) thrust washers that go on either side of the worm gear of the steering shaft back in. If I install them as they originally were, I can’t bolt the steering shaft bearing all the way on. I end up with about a 3/16 inch gap that I can’t close. I have to leave both out to bolt it up. And then, without either thrust washer, I end up with (I’m estimating) 1/16 inch motion along the shaft, and looseness in rotating the steering shaft. The thrust washers are just under 1/8 inch thick. Have I done something wrong? I had taken everything apart to change the two seals (steering shaft and worm wheel shaft) - and clean and paint. I removed the front end (manual calls it “steering gear housing”) and the housing base to get at everything. The only part I replaced, other than the seals, was the large steering worm wheel bronze thrust washer. Everything was tight on the steering worm wheel shaft before I bolted the bottom housing back up. There was no slack on the steering arm and it moved smoothly. The problem came when I tried installing the steering shaft. I had no problem getting the steering shaft down into the housing, but it is too tight. It seems like I now need much thinner thrust washers on the steering shaft. Can anyone tell me what I may have done wrong, or what to look for? Is it possible to have the worm wheel upside down and have the steering still fine, but yet create a different tolerance between the worm wheel and worm gears and therefore not fit with the original two thrust washers?? That's the only thing I can think is different, but it didn't look like I could get the splines of the worm wheel shaft into the worm wheel gear the opposite way so I didn't think I could have reversed it. I could sure use some ideas . . . . Thanks
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
