Farmall Tractors Discussion Board
Re: Power steering problem with M
Posted by GeezerMn on November 10, 1999 at 08:59:44 from (216.161.105.27):
In Reply to: Power steering problem with M posted by Rich Dahlke on November 09, 1999 at 18:05:43:
Check belts.A good pump should stall and slip
a tight belt when steering is turned to limits
left & right.
It sounds like you have a steering gear problem.A scuffed-galled worm and wheel in steering case or ball brg. on end of shaft will
cause this.Remove worm shaft,clean&check. These
aftermarket units worked very good and were put
on many makes of tractors.
Post a Followup
: Re: Re: Power steering problem with M
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
