Re: Noise in the rear axle of Super A
Posted by lee on September 06, 2004 at 08:24:29 from (24.24.95.246):
In Reply to: Re: Noise in the rear axle of Super A posted by MWireman on September 06, 2004 at 04:46:17:
keep second gear in mind but also keep in mind the clatter can resonate at different speeds so the speed associated with second may be a factor more than the fact it is in second. The gears themselves can be a factor even though they appear good. If you can pop the trans top, drain the trans lube, look for metal in the lube, you will almost always find some, look for bigger pieces, wash the whole thing down with diiesel and/or kerosene then some gasoline to get things real clean you can then get a good look at the gear teeth and mesh patterns, a cheap inspection magnifyer scope may work to get a better look. Layout die can be applied to the gear teeth to bring out the pattern. You can look at the bearings Hugh suggested and you may want to look into the outer bearing on the bull pinion drive axle also. Other bearings are more difficult to evaluate ie., the differential carrier bearings, the transmission drive and counter shaft bearings. The position of the second gear set on these transmission shafts may be a factor if one of the trans shaft bearings is defective. Happy hunting. This one may be elusive.
Home
| Forums
Today's Featured Article -
A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
