Re: Couple of quick questions about Farmall H
Posted by Bob M on October 12, 2004 at 06:14:44 from (165.170.128.66):
In Reply to: Couple of quick questions about Farmall H posted by Brian in NY on October 12, 2004 at 05:54:32:
Brian: 1 – Tension on both belts is set by adjusting the “split sheave” on the fan hub (for the fan belt) and on the generator hub (for the gen belt). To tighten either belt, first loosen the set screw that secures the threaded half of the split sheave to the hub. Then rotate the threaded sheave half as required to move it closer to the fixed half. A blunt punch and a hammer are helpful if the sheave is stubborn (they often are!). Helps also if you shoot a bit of PB Blaster, WD-40 or similar onto the threads first – but don’t get any on the belt! Suggest doing the generator first – it’s easier to get at and to understand the process. Once you have the generator figured out then attack the fan belt! 2 – If the ignition system is in good condition, the distributor cap and wires are in good shape (clean, no cracks, everything fits tight, etc), rain/snow falling on the distributor won’t cause any problem. However there’s nothing wrong with shielding the coil/distributor with a flap cut from an old inner tube, a trimmed plastic antifreeze jug, etc. 3 – Standard commercial grade nuts ‘n bolts should hold your snowplow frame just fine, presuming they are sized properly. My plow frame attaches to the tractor frame with 3/4" bolts threaded into the existing tapped holes in the fixed bolster and the front engine mounts. Happy snow plowing – it won’t be long now! (1st snow here in western NY is forecast for the end of the week...)
Home
| Forums
Today's Featured Article -
Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
