Re: 606 again
Posted by K.B.-826 on October 12, 2004 at 19:33:02 from (209.163.30.76):
In Reply to: 606 again posted by johann on October 12, 2004 at 09:59:17:
Johann, in every case of not getting the input shafts lined up that I have ever heard, the transmission gets damaged, never the engine. You would have pushed the input shaft right out of the TA before even coming close to hurting that crankshaft. As far as the knocking noise, What exactly did you do to the engine? Did it run before you had it apart, did it knock before? Did you carefully measure the crankshaft and check your oil clearances with Plastiguage? Everything torqued to spec? Pull the oil pan first and take a look around. You can remove the bearing caps without pulling the engine. Just for the fun of it, try to retorque your bearing caps just to make sure you didn"t miss a bolt. I"ve seen someone forget to do that before, and that engine knocked. What exactly happened when you didn"t get the input shafts lined up? Did you try to force the tractor together by drawing it up with the bolts? Do you know of any transmission damage? It"s possible that noise caused by transmission damage is echoing through the clutch housing and sounding like it"s coming from the bottom of the engine.
Post a Followup
Subject:
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
