Re: International Model M Grain Drill-Thanks
Posted by riverbend on October 14, 2004 at 19:14:43 from (208.160.34.160):
In Reply to: Re: International Model M Grain Drill-Thanks posted by rwlmak on October 14, 2004 at 10:25:08:
I hope that this is not too late. I know how it goes sometimes, timing is everything. I spent all day digging potatoes and did not look at the computer. This might be a little hard without the illustration. Gear C moves up and down when the latch B is set in the notches to select the correct gear on the cone shaped cluster. Sprocket A looks like it runs the chain to the feed shaft. There is also a cover on the feed mechanism in the bottom of the hopper. If you ahve an 8 tooth sprocket A, the most you can plant is 42 Qts. / acre with gear C set by latch B in notch 10. If you have a 16 tooth sprocket A, setting latch B in notch 4 will give you 48 qts./acre and notch 5 will give you 54 qts./acre. In all of the above cases, the cover on the feed mechanism goes on the left side (it appears to be the wider side). Good luck with your planting. Greg
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
