Re: regular cooling system
Posted by SproutW on October 17, 2004 at 22:50:45 from (64.4.164.73):
In Reply to: regular cooling system posted by PVF on October 17, 2004 at 13:18:19:
Regarding the coolant in the engine oil. The Regular used a wet sleeve principle and used rubber O-rings to seal the coolant from crankcase. I would think that would be the problem. You could also have a small crack in the block but imagine the sleeve seals are the problem. Pull your engine pan or look up through the inspection holes and see if coolant is leaking around the sleeves. You will have to pull the head and sleeves to correct the problem. I'm doing the same thing right now and have the sleeves at the engine shop. The seal grooves were bad and the shop is fixing them up for me. Hope this helps.
Post a Followup
Subject:
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
