Re: farmall super c hydraulic repair kits
Posted by CNKS on October 25, 2004 at 19:19:59 from (207.178.96.212):
In Reply to: farmall super c hydraulic repair kits posted by arthur gauna on October 25, 2004 at 19:09:24:
The o-rings you can find about anywhere. The gaskets from Case-IH are about as cheap as anywhere. If you are going to overhaul the reservoir, the kit from Case-IH costs $90-$100. Too much? Maybe, but it includes all you need for the reservoir, except the boots. If all you want to work on is the pump, it won't cost much, unless you have to use a speedy sleeve on the shaft. You may find that your 49 shaft has a seal (leaks into the crankcase), and the 53 an o-ring. If so you can't put a speedy sleeve on the 53 unless you enlarge the shaft hole.
Post a Followup
Subject:
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
