Farmall Tractors Discussion Board
Super A brake job
Posted by steve on November 18, 1999 at 08:39:17 from (12.10.147.50):
I need to do the brakes on my '49 Super A. What is the best way to remove the axle housing?
Should I jack up the tractor, and remove
the whole wheel and axle assembly together, or
jack the tractor, remove the wheel, and then try
to pull the axle housing off? I assume the housing weighs 100lbs+, so I'll get help.
There is no convenient way to grab onto the axle housing, it appears.
Also, I have the I&T manual, but are there any small parts that might fall out upon removing the axle housing? I don't want to create more problems than I'm trying to solve.
Other than replacing the seals and brake bands, is there any other maintenance I should do while it's
apart? I'll remove the bull gear covers, and clean out all the oil and sludge in them, while
the axle housing is off.
Thanks!
Steve
Post a Followup
: Re: Super A brake job
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
