Re: Farmall C with sickle bar
Posted by captaink on November 04, 2004 at 09:23:44 from (66.115.214.56):
In Reply to: Re: Farmall C with sickle bar posted by Bob Morris on November 04, 2004 at 09:01:20:
The C has two U shaped clamps on each wheel one inside and one outside with two bolts in each one. To move them I put a jack under the drawbar on the side I want to move and jack up until the weight is off the wheel. Rotate the wheel until the clamps are on the bottom of the axle and lower until you can’t turn the wheel. Then I loosen the bolts (might take a long wrench and some PB blaster or penetrating oil) a couple of turns until the clamps are a bit loose. If you have a port-a-power you can place it between the transmission cover and the wheel and use if to push the wheel out, but don’t use too much pressure, the wheel should move fairly easily. If not loosen the clamp a bit more. If you don’t have a port-a-power, then take a long pipe or bar and pry out on the bottom between the ground and the wheel, you might need to rock it a bit to get it to move. You may also have to adjust the height of the tractor to get the right amount of weight off or on the axle to get it to move. I prefer to not loosen the clamps excessively as a safety factor but if things get ugly and the tractor is stable on the jack you can take the bolts and clamps out completely, lower the axle in the resulting space and literally tip the top of the wheel out quite a bit and then jack the tractor back up. You need to be more careful now not to knock the tractor off the jack! The bottom of the wheel will then move out. You can repeat the lowering/raising until you get the wheel where you want it and then reinstall the clamps and bolts. Obviously this lowers the safety factor and I prefer to not do unless necessary.
Home
| Forums
Today's Featured Article -
Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
