Re: 460 farmall will not start ....NEED LOTS OF HELP!!!
Posted by Janicholson on April 03, 2009 at 16:59:34 from (66.173.50.26):
In Reply to: Re: 460 farmall will not start ....NEED LOTS OF HELP!!! posted by El Toro on April 03, 2009 at 16:35:55:
If it is hooked into the distributor, and the points are closed, it should read in the 6 to 8 volt area. But if the points are open, or it is disconnected from the wire, it will read pretty close to the same on both ends. A bad resistor will heat and open up in the short time it is "running" but I would think it would show a no spark when static tested as well. I would just bypass it for a trial to see if it is the cause. Just thinking out loud. JimN
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
