Re: welding Super M exhaust manifold
Posted by george md on November 20, 2004 at 11:37:09 from (65.216.222.101):
In Reply to: Re: welding Super M exhaust manifold posted by gusc on November 19, 2004 at 23:21:15:
gusc, Thank you very much for the compliments. After a day of fixing everybodies disasters ,it's somewhat relaxing to settle down and do some mani- fold repair (always do it late nite after the phones quit). Studs are usually not real hard ,a HS steel end mill will cut most, once in a while you may need a carbide cutter. If the mill is near tap drill size and you center well , the only thing left in the hole is the thread and they will come out like a heli-coil. Taking out broken studs and bolts isn't too bad , but when some clown tries to do it and breaks a drill in the hole then breaks an easy out (really called hard outs )in the hole on top of the drill, then the fun begins. That's when I wish I had an EDM machine. Oxy/acet cast iron is the best repair for cast followed by brazing and the absolute worst choice is arc welding. Any arc rod that will weld cast iron will have a hi- nickle content , nickle is about twice the tensil strength of cast and most important it has a much greater rate of expansion and contraction than cast . Cast is not ductile and can not give a little as the weld cools and that when the cracks start.It doesn't matter how many chipping hammers you wear out peening the arc weld bead , when you start the engine the manifold and weld change size again and do it every time you start and stop.Eventually the weld pulls away from the base material. For manifolds heat a large section or all to a dull red before welding , use reasonable amount of flux with the cast iron rod and maintain heat for a while after welding. Below is a link to how to weld cast , there are several pages , read all of them. george
Home
| Forums
Today's Featured Article -
Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
