Re: Timing marks on Farmall H
Posted by ChadS on November 24, 2004 at 11:24:46 from (66.228.96.212):
In Reply to: Timing marks on Farmall H posted by PA Steve on November 24, 2004 at 10:43:28:
If you have the engine torn down far enough to remove the cam, If the head is off, center the #1 piston at top dead center, then, the camshaft timing, there are two marks on the gear, one for the crank, and one for the distributor. Best advice for which timing marker is which, and knowing its correct, is to install #1 lifters in the block, they both should be down, or valves closed, if you have the piston all the way at the top, the cam in the right place, the markers should be darn near close enough to recognize as to where, and which one is which. Look up at where the distributor would mount up, there should be a mark there, and one at the crank. As for the mechanical advance, and timing, follow the book specs on the timing, and make sure the advance mechanism is not stuck, or sticking. If they are, that robs the throttle response from the engine idle to full throttle. Hope this helps a bit. ChadS
Post a Followup
Subject:
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
